Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 22re Vacuum leak!
View Single Post
Old 12-21-2003, 01:00 PM   #3 (permalink)
JeremyH
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Or, you can use carb cleaner (or some other highly combustible substance) and spray where you think the problem might be.....when you find the spot, the engine will either increase or decrease in RPM.
However, when you replaced the gasket on the throttle body, did you use a cork gasket or RTV??? This might be your problem if you used cork....they tend to leak.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
