If it isn't causing any problems you could live with it as mentioned above. If you are concerned about it you could use it only for the spare but that might mess up your rotation program. If you seldom use your snow tires you might consider mounting one of them on it.
You've lived with it this long. You could find another "good" one and then sell the odd one on Craig's list or eBay or something. Personally, I would just keep using it.
Kep
