Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - What weight fluid?
View Single Post
Old 09-12-2008, 02:01 PM   #6 (permalink)
Krusty
Krusty's Avatar
View Krusty's Photo Gallery
the first number is the viscosity of the oil---- and since you are not worried about 'flow' , it doesn't make a daymn bit of difference !!!!!!
any 75-80/90 will work !!!! (Marlin recommends 80/120 !!!) so what ???? the parts are immersed and won't know the difference !
as in engine oil----- toyota does not recommend Mobil 1-- so you shouldn't use it ??????
in the winter i run 10/40, in the summer i run 20/50--- (i live in the mojave desert and it gets HOT in the summer !
in the tires-- i usually run 28/35 psi in my '93--- in my 85, i run 8 and 5 psi !!! NOT what toyota recommends---- but they don't run 36's and don't know the application in which i use the trucks !!!!
toyota uses 'red' antifreeze--- so you can't use green-yellow-purple ?????
also found on TinBenders.org
Pirate4x4.com
92 22RE x-cab 4x
and a 86 22RET as a 'truggie' rock crawler
pics in photo gallery-- Krusty
Krusty is offline   Reply With Quote
