Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - are you better than four mechanics?
View Single Post
Old 09-12-2008, 07:05 PM   #3 (permalink)
new echo owner
just a nobody
It is possible that you have a crack or broken clutch pedal mounting bracket. When you press on the clutch pedal, the bracket is flexing rather than pushing the clutch master cylinder push rod to disengage the clutch. Get a light and look underneath the dash when the pedal is mounted, see if the bracket is flexing when you put down on the clutch pedal.
N.E.O.
