Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - out of shop - now overheating
View Single Post
Old 09-12-2008, 07:16 PM   #11 (permalink)
Vicoor
Vicoor's Avatar
View Vicoor's Photo Gallery
is it a new engine or remaufactured?
Or is it just new to your truck?
a clogged or restricted radiator could cause this symptom, as could low coolant level or a seeping head gasket.
The seeping head gasket may not cause coolant loss but may allow combustion gases into the coolant and reduce cooling system efficiency.
You should really have a higher pressure cap on it. 9 psi may allow the coolant to boil at too low of a temperature.
usually bad fan clutches cause overheating at lower speeds and in stop and go situations.
Don't talk about it, Just do it!
22RE, xtreme ported head, crane cam, cust manifold, MegasquirtII-Extra(full sequential inj/spark), 300cc inj, adj reg, supra fp, LCE header, W58, short throw shifter, 14lb flywheel, kevlar clutch, 4.10 gears &Truetrac, drop spindles...
Vicoor is offline   Reply With Quote
