Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Specs
Thread: Specs
View Single Post
Old 12-27-2003, 03:46 PM   #2 (permalink)
JeremyH
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Remove the tires and jack up the truck so that the suspension droops......you should be able to droop each side enough to pull out the spring and remove the coil spacer. You might find a spring compressor useful (Auto Zone should "rent" you one). As for the rear, you'll need to find some stock shackles. They are fairly easy to install.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
