Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - simple question...
View Single Post
Old 12-28-2003, 03:07 AM   #4 (permalink)
Stealth
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Uhm you need 3 fuses... well 3 if you use a smaller gauge wire after the distro block... like if you split 2 8 guages off of a 4 guage. But if you run a 4 and a 8 gauge off a 4 gauge you would only need to fuse the 8 gauge after the split. There should always be one fuse as close to the battery as possible.
www.knukonceptz.com
Wiring is so cheap there, there's no reason to go the cheap way on anything.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
