no heat required in my install.
just make sure the car is clean and spray soapy water and slide the clear bra there.
You have to move fast to cut the plastic so you can still adjust the plastic if you make mistake (don't let the soapy water drie up until you finished cutting it to follow your hood edge).
I used bug rubber eraser to push all the air bullbles out. and after all dried up, use small needle to poke the air bubbles if you have some there.
So far the bra has been on my car for 2.5 years, no problem, no bubbles or yellowing.
feel free to ask if you want to know more. it is really easy.
'08 Toyota Camry Hybrid
'00 Grand Marquis LS (winter beater)
'04 Porsche Boxster
Gone: '06 Solara
