Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Damn Battery Tie down keeps coming loose
View Single Post
Old 10-02-2008, 08:08 PM   #3 (permalink)
LE05
Gameroom cash: $285230
View LE05's Photo Gallery
Originally Posted by drunken_panda View Post
The vertical bar that holds the cross bar to the battery tray has come loose for the 3rd time. Im worried that one day I'm going to take a corner, the battery will go flying and tear all sorts of wires out. I have a Kirkland battery in. When I tighten down the bolt, it snugs up just fine with no side to side play in the vertical bar when grabbed.
Am I an idiot? It looks simple, the bottom hook, hooks in to the only gap thats there. It doesn't look like the hook or the hole is bent. and I know the bolt isn't loosening up.
are you sure the nut isn't coming loose? a new hold down bolt/hook comes with thread lock on the threads... so that may have worn away on your bolt over the years. simple check is to get some thread lock, and reapply it. if the bar no longer comes loose, that was the problem.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
