Originally Posted by ben805
I replaced the front door and dash speakers with DLS UP6i components and they're being fed by eD nine.2x amp(200wx2), the problem is....when I tap the LOC to the front door speakers output from the JBL amp...the tweeters of my components do not work, it looks like the OEM JBL amp have some sort of high-pass filter built-in for the front door speakers, when I tap onto the front dash speakers output from JBL amp I get no sound, also try to tap onto the L and R output from the JBL 6 disc changer (before the amp) and get no sound either.....WTF??
I would recommend looking into the Audio Control interfaces. These have always been a great solution piece for me. They have standard interfaces like the LC6 or higher end pieces like the DQL8 that gives you full control over your music. The Audio Control interfaces also acts as a line driver. Even some of the better aftermarket radios only give off like a 3 volt signal of audio into your amps, Audio Control will deliever upto 13 volts of signal. The pieces are adjustable to work with what ever amps you have these pieces hooked upto. The better signal means you will get better and cleaner sound.
