Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Spark-Plug tube removal tip...
View Single Post
Old 10-20-2008, 07:35 PM   #1 (permalink)
barthmonster
View barthmonster's Photo Gallery
Discovered this tonight, who needs a $70 tool !!
SPARK-PLUG TUBE REMOVAL TIP !!:
* Remove valve-cover
* Insert a nut from the spark-plug tube on the tube to be removed but
install the nut flat-side up.
* Insert another nut from a different spark-plug tube on the tube to be
removed flat side down (flat side to flat side)
* tighten the two nuts towards eath other (double-nut technique) until tight
using channel-locks or whatever.
* using an open-end 30mm wrench or channel-locks on the lower of these
two nuts, remove the spark-plug tube.
hope this helps someone out there...
barthmonster is offline   Reply With Quote
