Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - trd springs
Thread: trd springs
View Single Post
Old 10-22-2008, 04:45 PM   #7 (permalink)
Sundance_XR
Sundance_XR's Avatar
View Sundance_XR's Photo Gallery
Originally Posted by Wholemilk View Post
the TRD springs drops .5" in the front and 1.5" in the back. these springs will not require a change to the struts. for 200 bucks...i'd rather have a bigger drop in the front. a half inch is like lowering your tire pressure, not worth it. the rear however is a decent height drop compared to the front.
Wow thats even worse. I would NOT want a boat look it would have from the rear being lower then the front. I would rather the raked look, especally because the Matrix is a wagon.
Like you said, .5 is basically nothing, you can get that from letting air out of your tires. Stock stuts should hold up fine. I lowered my old 98 Accord 1.5 all around (gave it the boat look, should of went 2' in the front) 2 years ago and it is still going fine with the stock, 10 year old struts.
The Matrix seems to have alot of wheel gap, I think a 2' all around, or at least 2' in the front and 1.5' in the rear would make it look right. Around here you cant slam my car because of roads, or I think it would even look better lower then that. Not to mention the handling benifits you gain. I assume it would be like night and day with the Matrix because it is a tall wagon.
C'mon aftermarket manufactors, we are waiting!!
-Josh
Sundance_XR is offline   Reply With Quote
