Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - RT105 brake/suspension questions....
View Single Post
Old 10-22-2008, 09:55 PM   #1 (permalink)
superboosted
View superboosted's Photo Gallery
..Yeah,that is alot to ask,I know... :P
-So first off,anybody make any adjustable shocks for these cars,as I have figured out that I could use mustang II/pinto shocks in the front but there really are only good drag shocks available for those.And I am building a track/drift/fun car..so stiff wont be a problem. Ideas?I can find KYB's/monroe's but that is it.
-Next up is sways,I am going to use a 99' miata (EDIT,hits the inside of the tires)front sway bar on it as it is 1mm larger and I can heim joint the ends,but the rear is a different story(has leafs),I am considering using the front stock sway,and mounting it to the rear with u-bolts/bushings and then heim joints to the frame?Any input?Should i run a panhard bar as well? I am new to leaf rear,but would like to have little to no roll.
-Thoughts on traction bars?I understand how they work in a straight line but do they have advantages/disadvantages in corners,or daily use/misuse :twisted:
-And brakes,any easy upgrades as far as front calipers/rotors go..or am I going the full custom route..
And a pic of her last night as she traveled outside of the garage for the first time!
superboosted is offline   Reply With Quote
