Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - I can hear the fluid
View Single Post
Old 11-01-2008, 02:51 PM   #8 (permalink)
TRD VVTi
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
You're probably low on coolant. Be sure to check out why.
Usually the air will eventually bleed itself out as you drive. If you're low on coolant it won't.
Elevate the front of the vehicle and start it cold with the radiator cap off and the heater selector turned to the hottest setting. Let the car run until hot keeping the coolant full in the radiator. After the air is bled out install the cap and top off the reservoir.
2006 Camry LE Special Edition
