Originally Posted by deadfly
Hi,
I am trying to put a sub into my camry. But I can't seem to find any possible way to get the power cable from the battery through the firewall into the cabin.
Anyone done this and can shed some light?
thanks!
I noticed you are from down under, so are you right hand drive? If so, i dont know if the layout is different, but in my left hand drive, i went through where the driving shaft comes into the cabin. If you open your hood and slide underneath the steering column, you can remove the rubber grommet and find your way into the engine bay. Once there, you should be able to locate it. Good luck!
