Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - help! will not start after install
View Single Post
Old 11-09-2008, 08:57 PM   #3 (permalink)
JustinC25
View JustinC25's Photo Gallery
Originally Posted by hfmt93 View Post
I have a 150k mile 1993 camry xle with the 3vzfe v6 in it.
I bought it with a bad low end bearing. I would drive it around the yard knocking like crazy, so i know it started and ran before i pulled the engine.
I got a junkyard engine that i heard run before they removed it. So i know that the engine and car ran before i put the junkyard engine in the car.
I have installed everything and it will not start.
I do not have spark. I have battery power going into the coil but no power coming out to the distributor. I do not think it is the coil because the car ran with the bad engine in. I think it has something to do with a signal for the ignitor but do not have enough experience with cars to track down the problem. I am an aircraft mechanic so i understand the basics of the car, but not the subsidiary systems and ecu.
Please help me get this car running. What would you do next? Where do i look?
i can't find a wiring diagram for the 3vz-fe, but I'll do my best to help.
The coil gets power from the ignition switch, but grounds through the igniter.
If memory serves me correctly the ecm sends a signal to the igniter through the IGF terminal, and the igniter sends a signal back to the ecm through the IGT terminal.
If either of these connections are interrupted, the engine will not run.
Most likely a wire could have been cut during the engine swap.
I would try checking for continuity on both ends of the IGT, and IGF wires.
My dad had a simillar problem on his truck with the 3VZ-E.
On occaision the truck would not start, or it would die while driving.
It ended up being a bad connection on the IGT wire.
Do you have a EWD for this car?
If not try to get a Real Toyota EWD. They are very helpful.
I hope this helps,
Justin
JustinC25 is offline   Reply With Quote
