Yes, thanks for the replies. Just wondering if the top tube seals can be removed and replaced via removing the nut without completely removing the valve cover? Thanks again
Originally Posted by new echo owner
If the oil is just around the top portion of the wires, just the tube seals should be sufficient, if it is on the spark plugs and not much on the top portion of the wire, then the tube will need to removed to reseal. However, whichever needs t be done, valve cover gasket would be a good idea.
N.E.O.
