Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2 part all trac ?
View Single Post
Old 11-18-2008, 09:45 PM   #4 (permalink)
Rick89GTS
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
4th Generation
Originally Posted by clintster77 View Post
I didnt think about the the pressure plates. I assume you said that because the power to the front and rear wheels must not be a locked in 50/50 ratio.
If I rebuild the 89 tranny do you think It would hold up to 265hp
Clutch and PP are different from 162 to 165 and I'm not sure how the the AWD tranny would transfer all the power in your scenario.
A lot of guys do the 3SGTE + FWD tranny without problems running HP in that neighborhood. I'm not on expert on it, so take it with a grain of salt.
If you can rebuild the tranny, go for it. The 2nd gear synchro is weak and is usually "crunchy" on higher mileage Celicas. You can find used trannys for $50 to $100.
Rick89GTS is offline   Reply With Quote
