Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - what kind of amp should i get?
View Single Post
Old 01-09-2004, 08:05 PM   #2 (permalink)
JaJay721
View JaJay721's Photo Gallery
You have two 4ohm terminals built into the box. You have a lot of different choices as to how to wire them. You can either buy a 2 channel amp that can put out your desired power at 4ohm to each speaker or you can find a 1 channel 2 ohm stable amp that can power them both. Each of your speakers are 200watt RMS.
Personally I would go with a 2 channel amp, if you're looking to stay with Rockford, I would go with the Rockford Punch 801s.
The difference between mono (1), 2 channel and multichannel is just the number of channels the amp outputs.
JaJay721 is offline   Reply With Quote
