Ditto what Egodd5150 said. Replace the starter contacts first and see if this problem goes away. More likely this is the problem as the starter contacts will wear out through time and you will get intermittent starting problems... it starts one minute then the next, it won't. The replacement contacts are only a couple bucks and you will need two. If you have the V6, you can access the starter from the right front wheel well opening after taking off the rubber wheel well cover flaps and the metal tin plate.
2005 Dodge Neon SRT-4
- 11.9 @ 117 1.79 60' (best trap 120 mph)
- 30.8 mpg city/hwy (pulse & glide), 33.4 mpg hwy
- 228,000+ miles (still on original motor)
