Am I corect in reading from the oil pan???
If so, the engine will require a complete overhaul, its one thing to have a gaskit go out and have some coolant entering a cylander and goung out the ass, its another to have it coming out from the crankcase itself, my friend you have either a cracked head or two or a cracked block either way your in a world of shit right now.
My best bet is that you cracked either of them by overheating it, and to make things straight here, cooland is a majority water right, water is a cleanser not a lubricant right, cleansers washing bearing will cause a bearing to spin and a rod to be thrown right!!!(HINT), at the moment the block is junked out and no longer usable, it will require a teardown and inspection for cracks, if it passes, then those Aluminum heads are probably to blame then, but inspect them anyways, if the block passes then you can either rebuild it yourself, not recomended unless you can measure to with 1/10 of .001" (thats one tenth of one thousands of an inch and for example one strand of hait is usualy two thousands thick) or have it done for you, all in all as a do it yourselfer for me to do (and as a buisness I get wholesale price on everything) it would cost round bout 800 bucks, you Im estimating 1700 without breaking a sweat. So My final sugestion, call up junk yards and check out what they have, and see if you cant find a swap, or better yet if you can find the 5vzfe which is a 3.4 liter dohc version of the 3vze and 3zfe (3.0 liter) single and dual ohc.
the 5v has much more Horsepower and fp torque and better fuel economy, itll run you anywhere from 100 to oh say 500 for those engines, depending on how you go and who you go to.
Maverick.
