You may have an alignment issue or maybe the rear shocks are starting to fade and might need to be replaced. It's got nothing to do with weight. If that was the case, ALL xB's would be having this issue and your first set of tires would have had the same issue.
Check out your shocks and also make sure the wheel bearing is ok. No movement of anykind on the rear tire. Take it to a reputable place that you trust and ask them to take a look for you if your not comfortable making the judgment call on worn componants. If your at almost 50k and haven't had a alignment done....get that done either way.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
