Scion XB 1st Gen-Engine Missing-Coil pack issue - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xB Forum > 1st Generation (2004-2006)
1st Generation (2004-2006) Forum for the first generation xB
Old 03-25-2010, 01:41 PM   #1 (permalink)
View Sandro's Photo Gallery
I hope this forum has some other mechanics on board.
I have a 2005 Scion XB (89,000 miles) and the other night the engine lights came on and it began missing on cylinder #3.
I had new plugs so I changed them, no change.
Took it to Autozone, they ran the OBD and said "P0303-Misfire #3". So switched the coil-packs between #3 and #2 cylinder and now get "P0302-Misfire #2"
This seemed logical and to me it confirmed what I suspected that the coil pack (original) had failed.
I replaced it. But, dang, no change. Still missing. (I did change plugs to the expensive platinum plugs, but I doubt that had any effect.)
So I assumed that maybe I had gotten a bad coil (Borg Warner) from O'Reillys. They gave me a new one, tried it and still missing.
Any ideas?
Sandro is offline   Reply With Quote
Old 03-25-2010, 04:01 PM   #2 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
Put the original plugs(new of course) back in there. Use only what it's designed to use. If you're supposed to run standards, run standards. If your supposed to run platnum, run platnum. use NGK or Denso only.
I'll bet that might be your issue. let us know.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 03-25-2010, 04:31 PM   #3 (permalink)
Thanks, I'll let you know
Yeah I'm heading over to Wally World and get a new set. The NGK's have (I'm ashamed to say cause I'm an FAA licensed airplane mechanic) never been changed in 50k miles. The gaps were massive (.050 I'm guessing) and electrodes rounded off.
I did re-gap the old ones and drop them back in with no change better or worse.
I hope it's that simple. Maybe they are all so worn. I had noticed the past 6 weeks it was a tiny bit slower to start. Wife didn't notice it but I did.
I'll let you know.
Thanks again
Old 03-25-2010, 07:38 PM   #4 (permalink)
Duhhh
OK, fixed it.
My initial OBD test said cylinder #3 was misfiring. I had my cylinder numbering wrong. I was counting right to left for some reason. So I changed out a good coil for a good coil.
Went back to Advanced Auto and they said cylinder #2 was misfiring and the service guy showed me #2 cylinder. Boy I felt stupid.
So I went home switched the coil I thought was bad for the real bad coil and we were back in business.
And, with the right plugs now also....
Old 03-25-2010, 09:26 PM   #5 (permalink)
View boogs's Photo Gallery
Same prob, #4
I had the SAME problem today but mine was #4... changed plugs first, and finally went to get it read.
I was reading on another forum site that it's possible the coil packs are under a 100k warranty... have you read or heard anything about that?
boogs is offline   Reply With Quote
Old 03-26-2010, 03:10 PM   #6 (permalink)
HATEnFATE's Avatar
Good to hear your guys got it sorted out.
Jason Johnston
(800)342-7045
