Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Rods and Pistons - OEM Strength
View Single Post
Old 12-03-2008, 05:35 PM   #4 (permalink)
bigbird
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
View bigbird's Photo Gallery
the fuel system is a flaw mainly in FI applications. doesnt flow enough, the injectors dont flow well and the system is returnless style system. basically it runs lean with boost. but the fix is simple. even if you goin NA...which i still feel it would be hard to get 250whp NA from that motor, 255lph pump, jims fuel mod, higher flow injectors and a high flow fuel filter, a good tune and you should be good for 250whp.
youd be a fool to be fed up with this motor for a reason like this. its one of the best by toyota ever. look around you, how many of us complain about the motor other then its limitations as far as performance? not many. you got unlucky or the previous owner didnt take care of it.
anyways. unless you want to go FI i say either replace the motor stock or just get another car that will be faster if ya want somthing faster. since your keeping the auto anyways it will be slow no matter what you do. mine is.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
bigbird is online now   Reply With Quote
