The best way to do the job depends very much on what kind of equipment you have, and where and how you are going to get the job done.
If you are doing the work in the driveway of your home, pulling the engine and trans out from the top like Eye8Pussies said would be more simpler and straight forward, not that there aren't other ways. If you know what needs to be done, you can pull the transaxle back without completely dropping the subframe to get to the clutch and then the rear main seal, however, the amount of room you have to work with can be a problem when installing the seal.
N.E.O.
