Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Check Engine Light On Then Engine OFF
View Single Post
Old 12-05-2008, 01:32 AM   #3 (permalink)
bmw335
View bmw335's Photo Gallery
at first I had the code pull at one local mechanic: the code was p0402 which is EGR, and he also said knock sensor and ecu maybe bad because while he pulling the code, the signal from ECM is cut-off. I know the reason why ECM signal is cut off because it switch to safe mode. So the Knock sensor is the last things I think it is bad, but I can not accept the facts is that both sensors going bad at the sametime ? The EGR is working, it not stuck open or closed. I'm waiting for the Knock sensor arrive to do a knock sensor relocation. Hope it will work.
Mean while, any input will be helpful.
BTW what scan tool can read the code for 94 v6 1mzfe ? it has both obd1 and obd2 plug. I bought the innova obd1&2 but it not work on 1mzfe.
bmw335 is offline   Reply With Quote
