Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - clutch change hours ??
View Single Post
Old 12-05-2008, 06:52 AM   #14 (permalink)
barthmonster
View barthmonster's Photo Gallery
I did the front main that way. Removed the whole oil-pump and swapped out the front main in the pump then re-installed the pump. Used an extra gasket, but I was worried about the room.
If you're a gentle parts-handler type of guy, re-installation is not an issue, just lube the seal and slip the component with the seal in it back on the crank snout.
Thanks!
Clutch Kit ??
barthmonster is offline   Reply With Quote
