Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Check Engine Light On Then Engine OFF
View Single Post
Old 12-08-2008, 11:36 PM   #6 (permalink)
new echo owner
just a nobody
My mistake about the swap thing; not sure what I was thinking that day.
Your car has two knock sensors, one for each bank, and they are both underneath the intake connected to the outside with a pigtail harness, that is why you have a four wire connector.
P0402 is not one of the code that would trigger the fail safe mode; there must be another code. have you try to check for codes again? The OBDII connector should be behind the coin box.
N.E.O.
