The only way your going to do that is to replace the transmission with one that has a different set of gear ratios. It's not a computer controlled thing, it's physical.
Also, your engine isn't working very hard at 3K to keep your speed at 77mph due to wind resistance and all. If you slowed down the engine but maintained your speed, your engine is working harder because it's turning slower but still has the same amount of wind resistance(and other factors) pushing back. MPG isn't just your engine's RPM. The tranmission in the car is designed to be as efficiant as it can be at higher speeds. The gears in the vehicle are set to be as friendly as possible on our interstate system as they can be.
I used to have a sentra that at 80 mph would be spinning 4000 rpm. At that rate I would see 35mpg. if I slowed down to 70 mph, my mpg would drop to 28. My F-250 gets better fuel economy in 4th gear going 55-60 then it does in 5th gear going 55-60.
I've found that at 77 mph in my xB, I'll get around 24-25 mpg. If I slow down(reduce both rpm AND wind resistance) i can greatly improve that number. Since I'm not a slow driver, I don't see 30mpg in my xB and neither do majority of the xB drivers out there.
I know it's not what you wanted to hear but just how it is. The key is finding a perfect balance.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
