Rust in rear under spare tire - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xB Forum > 2nd Generation (2007+)
2nd Generation (2007+) Forum for the second generation xB
Old 06-22-2011, 04:19 PM   #1 (permalink)
View echo man's Photo Gallery
Angry Rust in rear under spare tire
HI everyone have 09 xb i have rust around black rubber plugs under rear where spare tire sits you dont have to lift car look under bumper in rear I looked at 3 other xbs same rust around plugs worried because its thin sheetmetal Anyone know if this common or even know they have rust problem IN couple years looks like rot out THANKS
echo man is offline   Reply With Quote
Old 06-23-2011, 07:25 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I don't have an xB so I can't say if its common, HATEnFATE should chime in soon, he'll know.
To fix it, you obviously need to find out where the moisture is coming from. Is it a leak draining to the lowest spot on the inside or spray coming up from underneath? Otherwise, all you need to do is sand the rust out and hit it with some epoxy primer (Por15 is great stuff), then an epoxy top coat if you want (not necessary tho). Epoxy primer will not absorb moisture like regular primer so you don't run the risk of it rusting underneath and causing more damage that you won't see until it bubbles the paint. Luckily its in a hidden spot so you don't need to worry about color matching or anything.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 06-23-2011, 08:15 AM   #3 (permalink)
ranger z520
View fishing freak's Photo Gallery
Rust
take it to the dealer,,, its a 09 and depnding on miles, still under warranty.. at least get it on record with toyota... hope this helps
fishing freak is offline   Reply With Quote
Old 06-23-2011, 09:13 AM   #4 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
I would take it to the dealer and def show them. that shouldn't be happening on any 2nd gens this soon.
I would do as Blue suggested(provided the dealer can't/wont do anything) and sand away the rust because it becomes problematic. get a good primer and hit the sanded area and then to take it a step further, spray it down with an undercoating type product that will seal the area and prevent ANY moisture from getting back to that spot.
I can see two reasons this would be happening.....
Spray from the underside of the car. Since that hole plug is a floor drain for the spare tire well, its also the low point on the rear body pan. When it gets wet, thats where the water will sit until it evaproates, If you drive any gravel it is worse because the dust will hold the moisture there longer then anticipated and cause it to rust even faster(my B)
You've got water getting in the spare tire well somehow and it's slowly seeping out of the plug and causing rust to form.
Either way, you've got to get that area cleaned and sealed before it becomes a perforated rust issue, because then, it wont be a cheap fix.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 06-23-2011, 07:17 PM   #5 (permalink)
Thanks for your fixes on problem got back from dealer cliamed it was from salt on roads pointed out only rusted around plugs also showed them on xb they had for deliverys same rust Going to fix before gets worse think in 5-7 years will hear alot more when they rot out its thin sheetmetal THANKS AGIAN
Old 06-27-2011, 01:35 PM   #6 (permalink)
on full afterburner
Gameroom cash: $1349297
I love this stuff:
http://www.kbs-coatings.com/
Worked wonders on my rust repair job. Depending on how big the problem it, this is a cheap investment if you don't mind getting dirty and doing your own work.
