08 XB Code P0351
Every week or two my Xb check engine and VSC warning lights will come on, it gernerally goes back off within a day. I took it to Advance this morning when it came on and the code was P0351. I've done some research but cannot come up with a solid next step to take. Has anyone dealt with this issue yet and know what is the most likely problem? Coil, ECM, etc?
During my research i did find the following TSB.
T-SB-0047-10</SPAN>
MIL "ON" DTC P0351, P0352, P0353, P0354, P0355, P0356 (T-SB-0047-10)</SPAN>
Some 2008 2010 model year vehicles equipped with 2GR-FE engines may exhibit a MIL ON condition with Diagnostic Trouble Code (DTC) P0351, P0352, P0353, P0354, P0355, or P0356 (Ignition Coil Primary/Secondary Circuit) stored in the Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM).
