xb rides hard - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xB Forum > 2nd Generation (2007+)
2nd Generation (2007+) Forum for the second generation xB
Old 11-02-2011, 10:45 AM   #1 (permalink)
mrspeedyt's Avatar
View mrspeedyt's Photo Gallery
xb rides hard
my wife says our '12 xb rides hard. so much that she now dislikes the car. i even lowered the tire pressure to 34 front and 32 rear... doesn't help... is there a 'soft ride kit' for the xb? are the struts or springs from a camry a fit?
mrspeedyt is offline   Reply With Quote
Old 11-04-2011, 09:59 AM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
You might want to lower the tire pressure a bit further, down to 30 PSI all around. Unfortunately it is an xB and not a Camry XLE so the ride will be a bit stiffer. I'd look into different aftermarket companies on the web and see what they have to offer.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 11-06-2011, 11:57 AM   #3 (permalink)
mrspeedyt's Avatar
another idea I am going to consider is a smaller diameter wheel and taller tires to maintain the present outside diameter (presently they are 16" with 205/55 tires)... 15" or maybe even 14" rims if they clear the brakes and have the correct offset.
Old 11-07-2011, 09:42 AM   #4 (permalink)
Need For Speed
True, having more of a sidewall will give you more cushion on the road. I don't know if 14's will clear your calipers but the 15's should.
Old 11-09-2011, 04:25 PM   #5 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
i know 14's wont clear but most of the 15's should. Depends on the spacing set aside for the calipers behind the wheel.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 11-17-2011, 03:41 PM   #6 (permalink)
mrspeedyt's Avatar
I'll try a stock 14" wheel from a late 90's tacoma someday... it looks that it may have the shape to clear the calliper... i'm not in any rush as the xb is now in my hands (bought something different for her...) and it rides fine in my opinon. I even raised the pressure to 40psi.
