Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Have you done the Sea foam/ Mystery oil?
View Single Post
Old 12-15-2008, 06:27 PM   #14 (permalink)
rangerruck
View rangerruck's Photo Gallery
first off did you do the treatment with the engine running , at normal operating temps? in other words, after allready running, or you start up, and let idle for about 1o to 15 minutes. Also, you turn off, and let stand for at least 5 minutes, I like 15. and you turn the engine off, as absolutely as fast as possible, as soon as it sucks up the last bit of stuff. then, you need to do a second treatment. You also only need to do 6 ounces at a time. so you divide your can into 3rds. Yours is about 5% of the results; so dirty, that the stuff partially liquifies the sludge and carbon, but because it is not hot enough, and you have so much junk in there, reattaches to plugs. your second application should be right away, not whether you think you need it or not.
rangerruck is offline   Reply With Quote
