Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2000 rpm idle after cleaning TB & IACV
View Single Post
Old 12-17-2008, 03:03 PM   #6 (permalink)
zero_gravity
'90 Cressida
View zero_gravity's Photo Gallery
sounds like you're hot on the trail of the problem. the dirty ISCV is very very common with the 7M. that and a dirty throttle body. usually a clean and readjustment is all that is required. also, you might want to flush out the PCV pipe while you're there, it gets blocked up easily. just use whatever cleaner you're using on the TB and ISCV. you'll be amazed at the crap that comes out of that.
best of luck and let us know how it turns out. if you find any of those parts damaged i have a few working spares around.
zero_gravity is offline   Reply With Quote
