dammit, it didn't record my post yesterday... I was gonna say check the throttle linkage/cable, throttle stop screw, and idle adjust screw.
The driveshaft carrier bearing is NOT press fit. the only bearing I ever had trouble with welded itself to the driveshaft because it was bad and overheated. I just cut the rubber part off and hammered it off. the other 3 I've changed just slipped off after removing the nut.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
