2008 Yaris lower ball joint replacement how - Toyota Nation Forum : Toyota Car and Truck Forums
Yaris/Scion iA, Vitz and Echo Forum Discussion area for all the Toyota Yaris/Scion iA, Echo, and Vitz owners worldwide.
post #1 of 3 Old 06-17-2017, 10:44 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy 2008 Yaris lower ball joint replacement how
Can any one explain how to put a rt driver side lower ball joint back in got it out but the rubber ripped trying to press it back in. it is all apart just do not want to rip another one I seem to be doing something wrong,Please any help would be greatly appreciated.
Debbie Schulte Beebe is offline
post #2 of 3 Old 06-22-2017, 03:04 PM
Stevo_Echohb05's Avatar
Quoted: 3 Post(s)
The ball joint is not sold separately from Toyota. Maybe the ball joint you can buy is for aftermarket control arms.?
Stevo_Echohb05 is offline
post #3 of 3 Old 06-22-2017, 09:27 PM
Quoted: 13 Post(s)
replace the ripped one, don't install it ripped. As far I know, use ball joint press kit w/ adapters or a shop press with proper stand/adapters and make sure to grease the orifice of the control arm where the ball joint presses in--also grease the outer circumference of the ball joint--so it can press into the control arm easier.When you get the ball joint, they usually come with a plastic-cone/cap-cover. Keep these on until the moment of installation to keep them clean and ripping. I think you can press the ball joints with those covers on. You might want to check some you-tube vids. When I did the echo-I just bought the a couple new moog control arms which come with new ball joints and bushings pressed in--I didn't want to spend the $$ to get a press kit...tho I have a suburban that needs a new front end rebuild, so I might have to..lol.
l33ch is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Yaris/Scion iA, Vitz and Echo Forum
User Tag List
Linear Mode Linear Mode
Back
