indepandant suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2005, 02:57 AM   #1 (permalink)
View hairyfreddy's Photo Gallery
Canada indepandant suspension
did ever somebody try to fix a indepandant suspension on a echo hatchback ?
like cutting the beam in the back and weld a sway bar ??? i know it's cheesy but should i have faith in that kind of challenge
hairyfreddy is offline   Reply With Quote
Old 10-06-2005, 02:33 AM   #2 (permalink)
View blueapple's Photo Gallery
Hell no.
blueapple is offline   Reply With Quote
Old 10-06-2005, 02:21 PM   #3 (permalink)
why? do you have a better idea to improve dramatiquely the handling of that car ??? more than the .. beam
Old 10-06-2005, 03:35 PM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
talk to Wraith. He has a hot lil kaka roach.
http://www.toyotanation.com/forum/se...earchid=306285
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 10-06-2005, 04:56 PM   #5 (permalink)
echo_hrs's Avatar
View echo_hrs's Photo Gallery
If you can out engineer Toyota and TRD, then go for it...My suspicion is that this mod would ruin the handling, chassis strength, and safety of an Echo...
echo_hrs is offline   Reply With Quote
Old 10-06-2005, 06:44 PM   #6 (permalink)
It's an echo, it's fun to drive but that's all it should be. To make it a little more stable, wider rims and tires may be a good idea. Lower the height might help too. Stronger springs will also benefit handling, but leads to uncomfortable ride, also, you need to adjust shock firmness/rebound and make sure they work well togather, which is very important and can be alot of work sometimes. Torsion beam itself is already like a sway bar, (not exactly but there really is no need ). Actually, echos can handle very well.. super light weight and all.
So, to improve handling, start with tires,rims, struts, and work your way up. But don't even think about replacing the entire rear suspension geometry. The chassis is not designed for it, you need to calculate all the stress point... find the right parts.. weld.. just forget it, the money can get you a very good used MR2.
If you want crazy handling, just buy a MKI and drive it for week ends. Echo is perfect, basic, fun transportation.
Old 10-07-2005, 01:52 AM   #7 (permalink)
thank you guys
Old 10-07-2005, 05:33 AM   #8 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
and echo can be made into a track monster...
And YES!!! echos need the rear sway bar to help them turn hard into corners...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 10-07-2005, 10:06 PM   #9 (permalink)
eeto........?
View _VVTi_'s Photo Gallery
thats one small track monster with big g-force
1994 Camry LE V6
Tokico blues + Vogtland / Depo headlamps / Clear bumper light / Silverstar / AEM CAI / Tenzo R Formula 10 + Kumho 215/50/17
_VVTi_ is offline   Reply With Quote
Old 10-07-2005, 11:42 PM   #10 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Actually I run Toyo RA1's on the track but thinking about the new Nitto NT-O1's, I want to check them out because everyone is raving about them...
MySpace:
