LSD for snow? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2005, 10:00 PM   #1 (permalink)
View theruckus's Photo Gallery
LSD for snow?
Hello all, this is my first post and I have a question that I'm hoping someone can answer. I am currently driving an all wheel drive car (non Toyota) but I'm planning to get a new Yaris within the next month. I'm concerned about winter driving, I spend a significant amount of time in Northern Ontario where there's often serious amounts of snow. I will certainly get good snow tires but here's my question... would it be worth installing a TRD limited slip differential to help with deep snow conditions (driveways, blasting through drifts, etc.) I'm curious to hear from anyone with Yaris / Echo winter driving experience in deep snow.
Thanks.
theruckus is offline   Reply With Quote
Old 11-24-2005, 10:15 PM   #2 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
Well, I don't have a LSD in my camry, but my 73 Lincoln Mark IV has one. I drove it when we got about 1.5 feet of snow earlier this year. I could not imagine driving that car with all that power without a LSD. I think it's a worthwhile investment. After all, you're buying a car. What's a few extra dollars?
I don't think it's an absolute neccessity, but it could help you out in more than a few ways.
HoboJoe is offline   Reply With Quote
Old 11-25-2005, 08:53 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
money better spent on a good set of winter tires instead...they would do you much better than an LSD....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 11-25-2005, 09:15 AM   #4 (permalink)
I agree that snows are a necessity. Snow tires are great on slippery roads and moderate amounts of deep snow but if you’re really trying to get through deeper snow (I’m talking about low speeds, driveways etc.) I’m thinking that the LSD would make a big difference. Effectively 1 wheel drive VS 2 wheel drive, double the traction with the LSD?
Old 11-25-2005, 11:52 AM   #5 (permalink)
echo_hrs's Avatar
View echo_hrs's Photo Gallery
With a high-horsepower RWD I could see it making a larger difference in the snow...With the Yaris (yes I own one), the moderate power coupled with FWD, I think tires would be the best investment, the LSD probably helping more with straight line drag racing over winter traction...
Cheers
echo_hrs is offline   Reply With Quote
Old 11-27-2005, 12:39 AM   #6 (permalink)
1993 Camry XLE
HoboJoe's Avatar
^That's probably why an LSD is so helpful on my Lincoln. It wieghs 5,600 pounds and has massive low end torque.
Old 11-27-2005, 09:03 AM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
I dont know the actual tran code of the Yaris yet but most likely the LSD will not fit in the C150 trans. Which is normally found in all the Echo and Yaris chasis...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 11-27-2005, 10:29 AM   #8 (permalink)
echo_hrs's Avatar
My new Canadian Yaris RS is stamped the NCP91 Chassis, same as the new JDM Vitz RS, which has an LSD available from TRD...
http://trdparts.jp/english/list_new-vitz.html
Old 11-27-2005, 11:50 AM   #9 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
soo ??? My echo is ncp12 same as a Vitz ... and the TRD lsd doesnt fit my tranny ...
MySpace:
Old 11-27-2005, 01:06 PM   #10 (permalink)
echo_hrs's Avatar
I've downloaded the Specs for the 06 Yaris transmission, it says that the previous 05 Yaris used the C150, the new 06 Yaris is using the C50 Transmission....
Not sure what that means for LSD compatibility...
Old 11-28-2005, 10:18 PM   #11 (permalink)
Interesting, it didn't occur to me that the LSD for the Yitz may not fit our Yaris but I guess it makes sense. I have to get out of the lease on my current car before I can get a Yaris anyway so I have time to figure it all out.
Curious, what's the differential gear ratio? Does it effect the final drive ratio?
Old 12-10-2005, 11:09 AM   #12 (permalink)
zen is in the next corner
View Porter's Photo Gallery
The "differential gear ratio" is the same as the final drive.
Based on these numbers, the '06 Yaris should accelerate more briskly than the '05 Yaris given the same engine power.
Porter is offline   Reply With Quote
