P0171 Lean fault fix problem solved - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2006, 10:18 AM   #1 (permalink)
View snowshoe's Photo Gallery
When climbing mountains, my 2000 echo with 60k miles on it, would have the check engine light come on and stay on. Took it to autozone and the code was p0171 lean fault. I took out the MAF(a plug and 2 screws) (located on the air intake plastic assembley just left of the front of the battery, looking at it facing the car). Shure enough the little thermistor (looks like a amber droplet of plastic about the size of a kitchen match head with 2 wires on it) was encrusted with black dirty muck. Cleaned it with a soft artists brush and alcohol(electronic parts cleaner). Everything ok now.
Just in case this happens to you this may be of help.
snowshoe is offline   Reply With Quote
Old 03-07-2006, 10:36 AM   #2 (permalink)
Ps: I did clean the 2 little air flow sensor resistors also(with sensor upside down looking ito it with a light you can see them). Soaked them in alcohol(filled it up and let it stand for 5 min) then flushed it out with computer key board cleaner.
SOS. P0171 (system too lean) problem. bxin Camry & Solara Lounge 15 01-24-2006 11:09 PM
Headlight Problem Solved reym General Discussion 4 01-17-2005 04:20 AM
Motor Mount problem and other, please help lazycat Camry & Solara Lounge 4 08-16-2004 09:32 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
battery & break light problem solved! CanadaGTS Archived Corolla threads 4 11-22-2002 09:32 PM
