Yaris Steering Wheel Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 01:45 PM   #1 (permalink)
View liveBLUE's Photo Gallery
Canada Yaris Steering Wheel Issue
Hi,
I am wondering if anyone who has the new Yaris 06/07 have some problem with the steering wheel. If you turn right, does the steering wheel return back to straight by itself without your hands help? Or slightly right cause mine doesn't, it is always tilted at an angle, I think around 5mm off. however, turn left is fine...I hope someone will know. Even Toyota said there's no problem with it. I had 2 japanese guy to look at it but they said it's fine. You have to be sensitive with the steering wheels. You can try like...turn your steering to the right at around 10degree or less, and do the same thing with the left when you are driving normally
liveBLUE is offline   Reply With Quote
Old 04-11-2006, 02:55 PM   #2 (permalink)
View stuts's Photo Gallery
Canada
Hey their LiveBlue I am sorry to say I don’t quite understand your post I get it a little but not totally maybe it has to do with the road you are driving on maybe it is slanted a bit or maybe the air pressure is lower in the right tires another thing the power steering that we have on our Yaris is different from normal power steering someone else can explain that better than I can but I know we don’t have normal power steering maybe that has something to do with it you are not use to it or something if I em wrong about the power steering please let me know sorry not the best explinations oh you could of hit a pot hole maybe
stuts is offline   Reply With Quote
Old 04-11-2006, 03:08 PM   #3 (permalink)
yeah I know we are using electric motor and not hydrulic pump...
When I am cruising on the road, parking lots, just anywhere. I am sure the road is flats. I tilted my steering wheels to the right/left at about 10degrees or less and let my hands off the steering wheels. the right side doesn't return back to straight (around 5mm offset) while the left side does. so if I don't use my hands to adjust the steering wheel, my car will be going a slight right if I keep on cruising. I hope this is more clear. I went to toyota twice for a check up, and have them to test my car with showcase model yaris. Even they can't sense the problem with the steering wheels until I told them to feel more carefully. Then they see something is wrong with it but not sure what it is. After 2 fixes, my steering wheel is better than before but still not perfect.
Old 04-11-2006, 03:19 PM   #4 (permalink)
Canada
Ya thanks Blue that is more clearer man dude that sucks the big one I am sorry to hear this it may be something faulty on the car EH so what is the next step what are you going to do?????????????
Old 04-11-2006, 03:24 PM   #5 (permalink)
I have no idea. If toyota couldn't find the problem, then it can't be fix. cause they already found the best 2 workman in their dealerships already. Both of them are japanese too. All I can do is not to let go my steering wheel for now. Until maybe another Yaris have similar issues or my steering wheel got more worse again.
Old 04-11-2006, 03:27 PM   #6 (permalink)
View Exlotusboy's Photo Gallery
If I understand correctly from your question, you may be referring to the car's caster setup. Toyota has probably set the Yaris up without a great deal of caster to help reduce rolling resistance. Less rolling resistance equals better mileage.
Just a guess... hope this helps.
EDIT: Here's a link to explain caster angle -- http://en.wikipedia.org/wiki/Castor_angle
Exlotusboy is offline   Reply With Quote
Old 04-11-2006, 03:34 PM   #7 (permalink)
Hey EXlotusboy,
I am not so good with car parts or names. so I have no idea what is the car's caster. but thanks a lot. i will try to look into it.
Old 04-11-2006, 03:45 PM   #8 (permalink)
I just thought of another possibility...
Your description also mentions somewhat vague steering. This may also indicate a factory setup that favors fuel economy. By having very little or no "toe-in" (another wheel alignment measurement), rolling resistance is also reduced. With the wheels aligned almost straight ahead (and I'll bet they are) the car will roll more readily; the trade off with this is that the car won't track as well, acting the way you describe.
Again, just a guess... but you might mention this to the technicians at your dealer.
Old 04-13-2006, 02:58 PM   #9 (permalink)
At the risk of looking like a geek, I found this TSB on your issue. Looks like this might solve the problem.
http://www.alldata.com/tsb/Scion/112...-01/index.html
Old 05-09-2006, 12:09 PM   #10 (permalink)
Canada
Hey Liveblue what is the update on your steering problems did you get it fixed yet??????
Old 05-10-2006, 10:57 AM   #11 (permalink)
View warhorst's Photo Gallery
i just sent my yaris for my first free service at 1000KM at my dealers.......my steering wheel seems to be shifted to the left.......so basically when i hold the steer straight( with the toyota logo straight)......the car shift abit to the right......
so after the servicing, it was a little bit better......still not 100% straight.......so is the steer alighnment a problem with the majority here?
warhorst is offline   Reply With Quote
Old 05-11-2006, 05:28 PM   #12 (permalink)
Canada
No steering problems for me warhorst as far as I can tell and I hope it stays that way Warhorst what the hell you are getting free service on your car its good for you nothing was offered to me no free oil changes nothing where is your dealer ship I have no idea where Jakarta is
Old 05-11-2006, 09:17 PM   #13 (permalink)
hehehe.......jakarta is the capital of indonesia......the dealers here kind of have coupons for free servicing at various mileage.....we just need to tip the mechanics....
Old 05-12-2006, 05:05 PM   #14 (permalink)
Canada
Oh nice nice warhorst I wish we had something like that over here in Canada with Jakarta I did figure out where it was after I did my post I should of known where it was but usually the people that come on here are either from Canada or the U.S. well that is the mass majority anyways I forgot to think broader sorry about that
Steering Wheel Noise Trd_Thunder 2nd Generation (2005+) 9 02-21-2007 12:05 PM
Dealer told me my steering wheel is supposed to be crooked! da5176 1st Generation (2001–2007) 8 06-13-2006 09:38 PM
repair steering wheel - wear on spokes celicaGTswan85 General Discussion 4 04-07-2006 04:45 PM
leather steering wheel rewrap? ea8631 Celica Forum 2 01-12-2005 09:21 PM
