Engine ping-Aargh! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2006, 06:03 AM   #1 (permalink)
View chainsaw's Photo Gallery
Engine ping-Aargh!
Hi-I've got a 2005 5spd echo (30,000 miles) that pings almost all the time-it's not loud, but fairly persistent under low to moderate accelaration. I've installed hotter plugs, colder plugs, a K&N filter, used SeaFoam, and have tried several tankfuls of high octane. No change. All other maintenance is done on time. The dealer says it's normal and the engine is not being harmed. I can't help but think otherwise. Also-on startup, there is the unmistakable smell of raw gas for a short time. Any suggestions would be greatly appreciated.
chainsaw is offline   Reply With Quote
Old 04-21-2006, 06:28 AM   #2 (permalink)
View D.A.L's Photo Gallery
Just make sure everything is well documented; even go back if you have to, so if this causes you problems in the future you will have a case for a claim. Subaru’s also had a problem like that where the engine sounded like it was knocking all the time but it was due to piston and tolerance design. It also did no harm.
Don
D.A.L is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 05:07 PM
