Eventhough I don't live in Canada, I do know that the ECHO hatch has the same exact engine as the sedan varient. As far as 04-05 hatches, they should be the same exact engine as its only a year difference, I see no reason it would be different. The xA shares the same powertrain, at least as far as engine as the ECHO sedan and hatch, the same 1.5ltr 108bhp 105ft tourqe-of course its different under the new SAE numbers, but its still the same engine. As far as transmission, that could be different. But I'm guessing your more concerned with the engine. As far as I know, its the same engine...maybe someone else can confirm it for you as well. Well to be safe, keep the recites and look up warrenties and money back stuff. Have you thought about going through TRD? Look at their website, even if the ECHO hatch is not being produced anymore they should have aftermarket stuff for it, especially since you have the RS trim. I hope that helps!! Good luck!!
Live faster than the speed of fear
