Yaris 2007-06 temperature display - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2006, 11:25 AM   #1 (permalink)
Yaris 2007 owner
View marclamy's Photo Gallery
Question Yaris 2007-06 temperature display
Hi Everyone! I'm a brand new owner of a Yaris Hatchback 2007 since yesterday!
Question for you freaks! I saw there's a temperature display near the odometer ... mine is not activated... Is there a cheap trick to activate it? Or I must go to my dealer and give him 500$ to put a 30 cents chip in my car???
Hey Thank you all!
Looking foward to hear from you!
Markymark
marclamy is offline   Reply With Quote
Old 06-30-2006, 04:00 PM   #2 (permalink)
View Blueberry's Photo Gallery
I dont beleive it should be on. It should come on when you start the vehicle and turn off when the engine is warm, then it shouldnt come back on unless your engine is running to hot/over heating .
07 Blue Yaris 5dr
05 Blk Echo 5dr
Blueberry is offline   Reply With Quote
Old 06-30-2006, 06:25 PM   #3 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $664959
View ECHOKnight2000's Photo Gallery
Hey Thank you all!
Markymark
What do you mean not "activated." I've never heard of a car where you have to "activate" the temp display..it should be working unless there's a blown fuse or some other electrical problem...as mentioned already usually a blue light comes on when you first start and then goes off when the engine is warm (that's if the car is equiped with idiot lights) unless you have an anolog set up but the hatch doesn't right? Sorry not to confuse you...bring it to the dealer and have them check it out...it should be under warranty (So don't let the stealership screw you!) and oh another thing make it a point to be there when they do check it out. Has this been happening since you got the car? Or not long after? I guess what I'm saying is when did you first notice it? Good luck and keep us posted!
Live faster than the speed of fear
ECHOKnight2000 is offline   Reply With Quote
Old 06-30-2006, 06:49 PM   #4 (permalink)
The Primordial One
View Tankota's Photo Gallery
If I remember right, on some versions in other countries the LCD fuel gage panel has an actual temperture reading displayed on it, probably for outside air... So since the probably use the same LCD, it's got the ability to display it, it's just not a feature available on ours. To get it to work it would depend on what controls the display.. if its the main ECU, and they use the same ECU for ones that do work, then all you would need is a way to connect the sensor. But I doubt it's that easy, or that the sensor and connectors would be easy to get..
I need to get a shop manual, maybe even one from the more supped up ones sold elseware.
I saw a sedan with a lether package even..
Tankota is offline   Reply With Quote
Old 06-30-2006, 07:16 PM   #5 (permalink)
Yaris 2007 owner
Thanks Tancota!
Old 07-01-2006, 02:36 PM   #6 (permalink)
View swng's Photo Gallery
There is an alternative which may or may not suit you. In Canada, you can buy a rear view mirror which can show both the outside temperature (thermometer) and the direction to which the car is heading (compass). It is a dealer installed option and costs more than Cdn$300 .
swng is offline   Reply With Quote
Old 07-04-2006, 10:25 PM   #7 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
It also automatically dims.
Funny how an OAT gauge isn't standard.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Yaris is now on Toyota.ca!!! echo_hrs Toyota News 32 11-23-2005 11:50 PM
Toyota Debuting 2006 RAV4 and 2007 Yaris @ SEMA Ratko Toyota News 1 11-02-2005 12:25 PM
