07 Sedan Remote programing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2006, 05:43 PM   #1 (permalink)
View imknotright's Photo Gallery
My 07 yaris sedan with keyless (no security) only came with one remote key for the keyless entry. Apparently this is normal. I was able to aquire another remote key for a decent price. Does anyone know how to program additional remotes? Can this be done without going to the dealer?
imknotright is offline   Reply With Quote
Old 08-25-2006, 10:53 PM   #2 (permalink)
Figured it out. For a Yaris with factory keyless remotes I used instructions for Toyota TSB EL004-01.
1- Driveres door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a
number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programing
Old 09-12-2006, 09:32 PM   #3 (permalink)
View yaris88's Photo Gallery
Australia Remote key for YARIS
Hi,
I want to do exactly what you did so wonder which remote key did you buy so I do not have too look hard for one.
Thanks in advance.
yaris88 is offline   Reply With Quote
Old 09-13-2006, 02:09 PM   #4 (permalink)
You have to open the back of the remote & look for a remote with the same FCC number as the one you have. I just typed the ID into a search in ebay for titles & descriptions & all was good from there.
Old 09-13-2006, 03:32 PM   #5 (permalink)
Thanks for the reply. I wonder if your original car key is the one that has the lock & unlock buttins as ppart of the key as different country might have different types?
Thanks.
Old 09-14-2006, 01:31 AM   #6 (permalink)
Australia Keyless key
If you can tell me what your FCC # is as I opened it and all it has is something like:
clbt/c/361/2003
Model B41TA
and found no where to have the FCC #
Thanks in advance.
Old 09-15-2006, 09:45 PM   #7 (permalink)
Sorry, I didn't realize you were down under. You probably do not have FCC down there. My model number however is B41TG so the FCC # probably won't be right for you. Here it goes anyway FCC: MOB41TG The IC: 2584A-B41TG. The remote (lock & unlock) are part of the key (see pic) I guess look for one with the same model number. The one I got says Scion, but I didnt care, the price was right.
Old 09-18-2006, 08:30 PM   #8 (permalink)
Australia
Thanks for the information.
Yes, The key looks exactly like mine but the key part # of mine is actually B41TA not B41TG as yours. I might take the risk of getting one like yours and try to see if it works. Will let you know how I go.
Thanks once again.
Old 09-18-2006, 08:36 PM   #9 (permalink)
Australia Keyless Remote
Did you get it from Ebay or from some other places as I no longer able to find the one you bought either.
Thanks.
Old 09-24-2006, 02:25 PM   #10 (permalink)
You could try giving this company a call:
http://www.keylessride.com/order/choosevehicle.asp
Search for 2006 Scion TC
Old 10-04-2006, 06:18 AM   #11 (permalink)
Australia remote programming
Yeah - bought the key exactly the same as yours but somehow the programming just does not take the key in. Any suggestion? very frustrating.
Old 10-05-2006, 08:01 PM   #12 (permalink)
It may not take it due to the model number nor being exact. Are the door locks reacting (locking & unlocking) when you are tryng to program it. If not you may not be doing it right.
Here is a link to the TSB I used : http://rav4world.com/tsb/EL004-01.pdf
Old 10-17-2006, 08:21 AM   #13 (permalink)
Programming key for Yaris sedan
It looks like the key is no good for the Australian Yaris as I can get into programming mode when lock/unlock kick in but pressing the lock/unlock buttons on the remote and lock button again does not get programmed as instructed in the instructions.
Old 10-19-2006, 06:56 PM   #14 (permalink)
Sorry to hear that. Get your hands on the right model remote that matches yours & you should be good as gold.
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
07 Camry LE aftermarket remote start just1guy 5th & 6th Generation (2002-2006 & 2007-2011) 13 08-11-2006 04:45 PM
07 camry w/ Remote start??? why???? profuse007 5th & 6th Generation (2002-2006 & 2007-2011) 14 07-12-2006 07:10 PM
07 Yaris S Sedan TOYOTaejien Yaris, Vitz and Echo Forum 8 04-27-2006 06:22 PM
LS430 remote programing transponder144 General Lexus Discussion 1 02-24-2006 03:13 PM
