2007 Yaris - Engine Vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2006, 10:12 PM   #1 (permalink)
View bry1023ny's Photo Gallery
Question 2007 Yaris - Engine Vibration
I test drove a 2007 Yaris Sedan with the 5-speed manual transmission several days ago. I was overly impressed with the car; however, I have one concern. During the test drive, when i opened the hood (with the engine running) I noticed a bit of engine vibration. Interestingly, during the test drive up until that point I could feel no vibration coming from the shift knob, the steering wheel, or the seats. I let the car idle for several more minutes and when I inspected the rear seats and the trunk I noticed the rear seats were vibrating a little bit.
My question for you guys is -- is this normal for the 1.5L VVT-i engine? Would the fact that I was idling the car for several minutes cause the car to exhibit this vibration? Is this common for these type of cars and/or fuel-savings?
In retrospect, I once test-drove a Honda Civic HX and that car vibrated much more. Even the shift knob would vibrate incessantly at idle.
Any ideas? Will this smooth out over time? Thanks guys!
bry1023ny is offline   Reply With Quote
Old 08-21-2006, 05:09 AM   #2 (permalink)
View 91MR2quickNA's Photo Gallery
As far as I know, the 1.5L 1NZ doesn't have balance shafts to counterbalance the engine vibration. Most of the vibration is controlled through the motor mounts. Engine vibration is normal due to the nature of the internal combustion engine. Most midsized sedans have liquid motor mounts to help counter this. I'm not sure if the Yaris has a liquid MM.
V banked engines (60, 72, or 90 degrees) vibrate more than I engines. However, long stroke I4s also exhibit harsh vibrations, which is why the 2AZ has balance shafts.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 08-21-2006, 11:46 AM   #3 (permalink)
View stuts's Photo Gallery
Canada
WOW this is some good explanation I learn something new everyday bry1023ny just to let you know I have vibration on my automatic as well I did not expect this when I first got the car but it is not a big deal at all you get use to it
stuts is offline   Reply With Quote
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Just purchased a new '07 LE (first post) with break-in procedures Forced Induxion 5th & 6th Generation (2002-2006 & 2007-2011) 9 07-17-2006 07:29 AM
Looking at the 2007 Yaris EngineerBoo Yaris, Vitz and Echo Forum 34 07-11-2006 11:26 PM
Toyota Debuting 2006 RAV4 and 2007 Yaris @ SEMA Ratko Toyota News 1 11-02-2005 12:25 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
