2002 echo alternator milage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2006, 10:22 AM   #1 (permalink)
View sinebar1's Photo Gallery
Does anyone know the approximate millege an Echo alternator should get? My 2002 has 107000 miles. I hear a screach every once in while when I turn on the AC.
sinebar1 is offline   Reply With Quote
Old 09-12-2006, 11:23 AM   #2 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $664359
View ECHOKnight2000's Photo Gallery
To be honest I don't know but I wouldn't want to find out the hard way and be stranded somewhere...you could ask a mechanic but at that milage I'm guessing your close?? Good luck!
Live faster than the speed of fear
ECHOKnight2000 is offline   Reply With Quote
Old 09-12-2006, 01:27 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
alternators don't screach. It is likely a belt that needs to be tensioned or replaced. Alternators don't fail necessarily from mileage or age.
Old 09-12-2006, 02:49 PM   #4 (permalink)
Does anyone know if the NAPA remanufactured alternators or anygood?
Old 09-12-2006, 08:32 PM   #5 (permalink)
bgrieger's Avatar
I've used them before. Never had a problem with them. Given your problem comes when you turn on the AC, why lean to the alternator conclusion...if there's a charging problem, you will see it in far more obvious ways. It's probably the belt to the ac that needs tensioning. You said when you turn on your a/c it squeals...that's just the same time as the a/c puts load on the belt and it probably starts to slip.
Maintenance for 2002 echo dephiler Yaris, Vitz and Echo Forum 2 05-04-2007 01:10 AM
Coolant drain 2002 Echo willpeavy Yaris, Vitz and Echo Forum 1 04-19-2006 03:44 PM
Echo 2002 no key transponder144 Yaris, Vitz and Echo Forum 3 03-07-2006 01:51 PM
2002 Echo alternator Darknights Yaris, Vitz and Echo Forum 1 09-19-2004 08:56 PM
2002 Corolla tape deck in 2003 Echo louise Audio, Video, and Security - Tech 1 08-04-2004 11:07 PM
