Glove box + Front Cabin Floor light with interchangeable LED - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 04:23 AM   #1 (permalink)
View yoshii's Photo Gallery
Hi
Anyone interested for the following LED setup using ultra bright led various color 100 VA (wide angle instead of focus), the setup would be possible as below:
Glove Box LED
a. 12-13.8V Car Batt - 4 Ultra Bright LED various color
Adv : Need not worry about replacing batt at all but must always remember to close glove box when not in use. If going for long oversea trip, circuit can be disabled by taking out one of the led. Will not suffer dimming light due to weaken 9V battery after long usage. Brighter than using 9V battery.
b. 9V battery source - 3 Ultra Bright LED various color
Adv : Only 9V battery will dry up if forgot to close glove box and hence cheap to replace.
Both with hidden switch that operate with open on, close off logic. Resistor incorporated in design for setup a to protect the LED. Both setup will be flexible for future change of bulb which mean you can change the color or replace a bulb easily without the need to do resoldering yourself. Installation will be done in north woodland area during weekday 9pm+ or weekend anytime.
Note : Both setup can be reverted to stock easily. No cutting of wire or hole made in your car. Don't worry.
a. 12-13.8V Car Batt - 4 Ultra Bright LED (color white $20, blue, green $19, orange red $18)
Nick Contact Color
1.
2.
3.
b. 9V battery source - 3 Ultra Bright LED (color white $14, blue, green $13, orange, red $12)
Nick Contact Color
1.
2
3.
Front Cabin Floor LED
4 x LED color white $35, blue green $32, orange , red $30 for both driver and passenger cabin (Total 8 LEDs). Can be tapped to open door or on-off switch to your liking. Setup will be flexible for future change of bulb which mean you can change the color or replace a bulb easily without the need to do resoldering yourself
Switch configuration can be as followed:
1. Tapped to on off switch
2. Tapped to door sensor
3. Tapped to 3way switch (door on off) (extra charge)
Nick Contact Color
1.
2
3.
Car Alarm Scanner Light
With installation priced at $25
Contact 98271660 for details.
yoshii is offline   Reply With Quote
*DIY* Stock Stereo LED color change - (Lots of PICS) - 56k no way SnakeyeS Camry & Solara Lounge 56 12-09-2010 02:51 AM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
