Pod filter installation
Hi everyone!
This is my first post on Toyota nation and i was hoping some of you would be able to give me some advice.
I've been trying to install a pod filter on my echo and i'm having a few issues!
I took out the original intake system and put the pod filter on the exitsing rubber pipe.... Initially i had issues getting the car to start, then i worked out that if i unclipped the air flow sensor i could get the car to start. When i went to take if for a drive the car refused to go above 3000-3500 revs.... is this something that can be solved with some clever rewiring or is there a simpler solution?
Thanks everyone... look foreward to chatting to yall bout what mods i should be doing!
