Always use the stock plugs, each plugs type have it's own characteristics and the only extensive testing done by Toyota engineers that fit the ignition advance (they can affect Max cyl pressure angle), combustion chambers turbulences and coil packs, are the stockers. Many problems have been traced to fancy or improper # plugs. Fancy metal plugs are just for long service life, just change them more often.
Torque, if you don't have a torque wrench, as much as you can comfortably give with one hand holding the ratchet your thumb on the pivot point, insert the threads all the way by hand. A bit of anti seize compound is nice there, save some swearing later on, specially with the new 192 000 km plugs on the Yaris, I would pull them out mid way or they will seize solid.
I don't have the torque specs, but don't use a 1/2 TQ wrench on it's lower range, good way to pull the threads and to hell the day goes...
