Exhaust Doughnut Flex Gasket Alternate - 2000 Echo 4door - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2006, 10:55 AM   #1 (permalink)
View backwoods's Photo Gallery
Hi,
The flex gasket between the exhaust manifold and the rest of the exhaust system has rusted out on my 2000 echo. The dealer wants $56 CAD for a new one. I have seen similar OEM gaskets for other cars at $10-15 max. Has anyone found a match from another vehicle that will work? Would be a shame to get raped by the dealer. I'll keep looking too.
Thanks
backwoods is offline   Reply With Quote
Old 11-24-2006, 01:03 AM   #2 (permalink)
View Pars's Photo Gallery
$56 doesn't seem like much, if the dealership had to diagnose the problem.
Pars is offline   Reply With Quote
Old 12-10-2006, 01:55 PM   #3 (permalink)
I diagnosed the problem. Pretty obvious where the leak was. The price is for the small gasket only. It's a special gasket, but not that special.
Old 12-13-2006, 08:49 AM   #4 (permalink)
BobProd
View rfice's Photo Gallery
Canada
Toyota's kit also includes the bolt's and springs, as the old ones will be useless once removed.
rfice is offline   Reply With Quote
Old 12-13-2006, 07:40 PM   #5 (permalink)
View emi323i's Photo Gallery
cheap.. do it
'00 toyota echo
emi323i is offline   Reply With Quote
Old 10-11-2011, 07:35 PM   #6 (permalink)
rudecam's Avatar
View rudecam's Photo Gallery
just bought the flex gasket kit (donut + springs) for 27$can at Carquest. installation seems simple. 56$ seems to me a bit too much for a ring of metal, 2 bolts and 2 springs.
rudecam is offline   Reply With Quote
Old 10-12-2011, 09:02 AM   #7 (permalink)
JNEG
JNEG's Avatar
Gameroom cash: $284100
View JNEG's Photo Gallery
I think I need the same part; let us know how the installation went, please.
JNEG is offline   Reply With Quote
Old 11-06-2011, 09:04 PM   #8 (permalink)
rudecam's Avatar
well it went like crap!
one bolt snapped on me and now i got to find a way to remove it! i'll see a mechanic about it. i'll keep you updated on any tips
http://imgur.com/J789c
http://imgur.com/FROba
Old 11-10-2011, 08:43 AM   #9 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
How'd you make out? If you're still stuck soak the area with penetrating oil or some such (WD40 works but not so quickly). Let it work overnight and the get on it with vice grips. Buy all different shapes and sizes of vice grips as this won't be your last broken fastener, don't ask me how I know! If you can give it a swat on top like trying to drive it in that'll help too in loosening the corrosion link in the threads. .
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 11-14-2011, 07:20 PM   #10 (permalink)
rudecam's Avatar
ended up taking the exhaust manifold out without much pain actually.
once the manifold stray was take off (mine is useless because it rusted through), it was easy to reach the 2 lower bolts. the upper bolts were taken with an articulated ratchet. percussion was enough to free them from their treads.
then i drilled through the rusted bold and remade the threads. buffed slightly the exhaust to take off a bit of rust but too much so that i wouldn't seal properly. get a new gasket put everything together with anti-cease and it's ready for battle!
got to say, if you a friend-genius to show you how, it greatly helps
2000 Echo - O2 sensor failure Ashla Yaris, Vitz and Echo Forum 4 03-15-2006 03:48 PM
exhaust gasket help? bowlofturtle Camry & Solara Lounge 13 12-02-2004 10:16 PM
2000 Echo 2Dr. Questions redvalkyrie Yaris, Vitz and Echo Forum 0 08-22-2004 06:29 PM
Odd Idle on 2000 Echo Todd Soden Yaris, Vitz and Echo Forum 2 02-25-2004 12:03 PM
